Change Drawings in one shot
I have large no. of 2d drawings created in SolidWorks 2009. I need to insert blocks and make similar changes across several 100s of drawings. Is there any way I can make these changes in one shot or any simpler method rather than opening each drawing and making the changes?
One method I can think of is placing the drawings requiring the similar changes into a folder and run a macro on them to make the changes. The problem is the placement of block or changes I need are not at same locations in the drawings!
Any suggestion is highly appreciated.
RKam
RKam
RE: Change Drawings in one shot
