Solver Problem. Zero pivot when processing D.O.F 11 of 49 nodes
I have a question regards a thermal-electric analysis. I am trying to model how the electric potential will behave in a conductive material. I apply electrical potential at the corners of a material then I had to use a subroutine to use the electrical conductivity interaction GAPELECTR. Though, my program gives me the following warining:
Solver Problem. Zero pivot when processing D.O.F 11 of 49 nodes. The nodes have been identified in node set WarnNodeSolvProbZeroPiv_11_1_1_2_1
Any suggestions on how to fix this? Also, the nodes that are shown vary with different runs..... :S
RE: Solver Problem. Zero pivot when processing D.O.F 11 of 49 nodes
For example, for steady state heat transfer the default boundary condition is zero flux, which means "insulated" b.c.. In this case (heat transfer), if you prescribe a certain flux for a portion of boundary and nothing else for any other boundary region, the analysis will abort with zero pivots messages.
