Convert to PDF with appending Revision to filename
I'm a looking for a macro or a means to convert a batch of drawings into pdf file format. I know that SW Task Scheduler will do this, but is there an add-on that will force it to add the revision from the properties.
eg: 22147-A.pdf instead of 22147.pdf
Thanks!
-D
Thanks!
-D
RE: Convert to PDF with appending Revision to filename
