First attempt at material nonlinearity, problem with plastic region
Hi all,
I finally got my model of helical spring compression to run.
Initially to keep the model simple, I define only E = 29,000,000 psi and PR = 0.3. The result seems a little high especially at the toward the end with larger compression (see attached graph).
Then I attempted to define both the Elastic and Plastic regions.
Elastic:
E = 29,000,000 PR = 0.3
Plastic:
Yield Stress Plastic Strain
1 29,000 0
2 35,600 0.000235
3 42,600 0.000474
4 63,400 0.001377
5 69,600 0.0018
With the plastic region included, the result is too low (the final force is only 40% of test data).
What am I doing wrong? Many thanks,
Elastic:
Plastic:
1 29,000 0
2 35,600 0.000235
3 42,600 0.000474
4 63,400 0.001377
5 69,600 0.0018
RE: First attempt at material nonlinearity, problem with plastic region
Please leave your model here to be considered.
Good Luck,
Mohammad Shahbazi
http://www.omranafzar.com
shahbazi@omranafzar.com
Please DO NOT respond to me directly but post all responses here in the newsgroup so that all can share the information.
Mohammad Shahbazi
Please DO NOT respond to me directly but don't hesitate to post your response here so that all can share the information.
1) Where is the stress-strain data that you are basing the material model on? Is it from a tensile test..?
2) Are you using true stress and strain?
Martin Stokes CEng MIMechE
corus
