Solidworks to DXF for plasma table burnout
Hello all,
I have a question about converting a solidworks model to a .DXF format that a customers plasma table can read for the burnout. I have no experience with AutoCad and I did a search for this but could not find the right questions. If I have a SW part model (flat steel) and send to a SW drawing, then export to .dxf, is this a format that a plasma table can read?
BB
BB
RE: Solidworks to DXF for plasma table burnout
-Dustin
Professional Engineer
Certified SolidWorks Professional
Certified COSMOSWorks Designer Specialist
Certified SolidWorks Advanced Sheet Metal Specialist
BB
Grant
Applications Engineer
SW2009 X64 SP 1.0
Dell Precision T5400
Nvidia Quadro FX 5600
Xeon 2.5GHz Quad Core, 4GB RAM
XP Pro X64 SP2.0
By doing it this way you solve some of the scaling problems associated with going via a drawing. It's only funny when someone else gets a part back 1/10th the size it should be.
We would always then open the DXF and add a dimension and resave before sending, just to make sure there weren't scaling issues. Saves stuff ups at their end.
Cheers,
Craig
