Error during data management open
Hi All-
We had a power surge in our building yesterday, and afterwards I-DEAS was no longer able to open. Upon startup we all receive the message, "Error during data management open. Operation continued. You should immediately export an archive file."
Obviously, we don't have maintenance, because that would be the intelligent thing to have.
Anyone ever see this before? I've been trying to locate the solution, but to no avail.
Thanks in advance.
Thanks in advance.
V
RE: Error during data management open
When I click OK, I-DEAS freezes.
What is the TDM? The library database?
V
Is there any way to check associativity between the central library and each individual install?
V
I can open a new model file, and get into everyone's individual files, but the central library files don't seem to be there. I can go into manage bins, and even see all the projects in the library, but it shows that there are no files in those projects.
There is some kind of connection off between the workstations and the library. I just need to figure out how to reset that connection.
Any help is appreciated.
V
Part of the problem is that there are to many items residing in your model files. reduce the number of model file and clean up the tdm with the dmadmin tool and you should be good to go.
