Foundation Design for 10'D Asphalt Tank
Our typical foundation design for small asphalt (or other elevated temp. products) is simply a raised concrete slab with a sheet of asphalt impregnated fiberboard between the slab and the tank bottom. On a recent project, on of the other engineers in our office designed in (4) radially spaced 1 1/2"W x 1/2"D grooves in the pad. These grooves were sloped from the center of the pad to the edge supposedly to help remove moisture from below the tank (or actually from below the fiberboard). Has anyone ever seen a design like this? His feeling was that the hot product would create "sweat" below the tank bottom, keep the fiberboard moist, and eventually corrode the tank bottom. I've always assumed the fiberboard would keep moisture out and therefore thought the grooves weren't necessary.
RE: Foundation Design for 10'D Asphalt Tank
