Pipe to flat sheetmetal pattern
At the moment I'm busy creating an intake suction pipe for a dredging vessel. But I have problems with getting it all to work in NX5.
The situation:
I've one sketch which contains a circle and another sketch at an offset with a sort of dented oval. Both sketches need to be combined into one pipe. I'd get it sort of working with Through Curves, but it's not ideal.
Nevertheless I converted the pipe to sheet metal (in four stages) and tried to create a flat pattern. I get an error that NX cannot compute. I already split the pipe by subtracting the material, so it should me possible to create a flat pattern.
How do I get this to work? And how do I get both sketches combined into one pipe the best?
The situation:
RE: Pipe to flat sheetmetal pattern
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Cypress, CA
http://www.siemens.com/plm
http://www.hollandscheijssel.nl/i/p/20csd500cl.jpg
The pipe is oval at the intake (half seen at the bottom of the picture), and at the end of the suction pipe it's completely round. This way it can be flange bolted.
Now there may be another approach which might work but we would need an actual part file. Besides, we might also be able to help with your Surface Thru Curves.
John R. Baker, P.E.
Cypress, CA
I can't provide you with an NX model because of our company policy.
