family tables
family tables
lately i'm getting run time errors when working in family tables. Wich results in a fatal error of NX.
See attached doc.
Someone with the same issue or solution?
Thanks in advance.
Running NX 4.0.4.2 MP6 with tceng0913.
Michael
See attached doc.
Thanks in advance.
Michael
RE: family tables
1)Open the spreadsheet goto Tools->Add-Ins and browse to the UG root directory and select ug.xla.
2)Then open unigraphics and open the part you have mentioned, and create the family parts. (You should not get the error now)
You should be able to create the part families in your login, then onwards, in the same system.
This error is system specific.
RE: family tables
I copied the ug.xla file from UG root directory to the add-ins folder of excell.
Seems to be working fine for now.
Thank u.
Greetz
Michael
