Pipe insulation
Pipe insulation
I need a spec on pipe insulation. I have a 1.5" force main in a roadway that is crossing a culvert. The pipe will be burried the gravel shoulder with about 1' of cover.
Also any comments on a type of sleve/conduit (ie 8" PVC SDR35 ?) to place the force main into to act as a containment if the force main were to leak.
RE: Pipe insulation
MIkolay
RE: Pipe insulation
