24V DC Votage Detector-Relay
I am looking for a low consuption 24V voltage detector.
Basically this device shall only detects the voltage presence.
When voltage is detected then a relay actuates, or 24V DC contacts closes. The amp rating for those contacts can be around 0.5 Amp.
The trick is to find a relay( electrical or electronic) with low consumtion power!!!
I appreciate any feed back on this.
RE: 24V DC Votage Detector-Relay
Check out products by Crydom and Grayhill for starters, there are plenty others. Start with Google!
if it is only a signalling you might use a logic port to detect and use a led indicator or use a opto coupler to transfer the signal to another circuit.
Robert-Jan
If you can be a bit more specific, other options might be better.
Charlie
