Merge drawings
Merge drawings
Merge drawings
I have three drawings, all the same size and I'd like to make them into a three sheet drawing.  Is there an easy way to do this?
RE: Merge drawings
Open the sheet you want to move. Right click on the sheet tab (Usually shows Sheet 1)at the bottom left hand corner. Click copy. Open the drawing you want to contain all three sheets. Right click on the sheet tab again. Click paste. Lather, rinse, repeat.
Joe Hasik, CSWP/SMTL
SW 09 x64, SP 3.0
Dell T3400
Intel Core2 Quad
Q6700 2.66 GHz
3.93 GB RAM
NVIDIA Quadro FX 4600
RE: Merge drawings
did the trick, thanks
RE: Merge drawings
No problem. thumbsup
SW 09 x64, SP 3.0
Dell T3400
Intel Core2 Quad
Q6700 2.66 GHz
3.93 GB RAM
