Pressure limitations for ASME B31.3 and B31.11 codes ?
Hi.
I was looking for the pressure limitations of those codes and I couldn't know a couple of things:
1. I found that B31.3 code has 15[psi] as a minimium pressure and the max pressure is calcuated based on the B16.5 PN 420 (Class 2500) max pressure, that consider the material and temperature to define the max pressure, but... the material that I'm using is API 5L x70 wich is not specified in the tables, the tables just consider the ASTM materials nomencalture (B16.5 Table 1A)... I asumed to consider 1.1 Material Group (which gives me 6170 psig as the max pressure) but I'm not sure whether that's correct when i want to work with API 5L x70. Am I alright?
2. For B31.11 code I found 15[psi] as a minimium pressure but I couldn't find any place where the max pressure is mentioned.
Do you guys know how I can get this max pressure?
Is the same that in the B32.3 case?
Thanks a lot for answering me.
RE: Pressure limitations for ASME B31.3 and B31.11 codes ?
For example, with an ASTM A515 gr.70 the code works up to 6170 psig (more than that pressure it's a high pressure piping), for higher presures you have to apply special rules(chapter IX).
In other words I want to know what is considered as a Pressure Piping, (from X?[psi] pressure and below Y?[psi] pressure it can be called "pressure piping"). For B31.3 and B31.11 codes.
Maximum pressure is whatever you can calculate for your material with its specific allowable stress, the wall thickness you're using and the temperature to which it will be exposed.
For your unlisted materials it is calculated per
323.1.2 Unlisted Materials.
"Pumping accounts for 20% of the world's energy used by electric motors and 25-50% of the total electrical energy usage in certain industrial facilities."-DOE statistic (Note: Make that 99% for pipeline companies) http://virtualpipeline.spaces.live.com/
