scrubber internal nozzle diameter
WHEN SIZING A SCRUBBER I FOUND A 'MOMENTUM CRITERION' TO SIZE THE INTERNAL NOZZLE DIAMETER IT WAS/
mean density of the mixturein the feed pipe*(velocity of the mixture)^2
it's value must be < 6000
can u explain for what is this criterion and if i have a momentum > 6000 what shall i do
thx
thx
RE: scrubber internal nozzle diameter
Cut the flow in half and buy another vessel just like it and run them in parallel.
"Pumping accounts for 20% of the world's energy used by electric motors and 25-50% of the total electrical energy usage in certain industrial facilities."-DOE statistic (Note: Make that 99% for pipeline companies) http://virtualpipeline.spaces.live.com/
i'll be sooo thankful
This is as close to rocket science as piping and fluid mechanics can get
http://www.aticourses.com/rocket_tutorial.htm
