Center of gravity
Center of gravity
Center of gravity
Hi
I have a FEM of an ultracapacitor pack. how do i determine the C.o.g of the assembly?
Prasanna
RE: Center of gravity
run the model with 1g inertia load to create a moment along the cg co-ordinate you want; ie, apply 1g in the x direction, calc sumMy of the reactions to determine the z co-ord and sumMz for the y co-ord
Hi
What software do you use?
In some of them you can simply check "Mass properties" and get COG. Doesn't require any analysis at all.
Thomas
Thanks 'rb1957' & 'ThomasH'
@ThomasH - am using catia for modelling, Hyperworks 9.0 and Ls Dyna 9.71
Catia does this easily with the 'Measure Inertia' button!
@thomasdw & Thomash - Thanks..I found it both in catia and  Hypermesh (btw HM was easier as I had already input the mtrl properties)
