1:1 DXF output from task scheduler
I need to export dxf files from solidworks to full size 1:1 scale even thought the solidworks drawings are at different scale. I can do this if i do each drawing individually by enabling 1:1 output but i have a lot of files to do at one time and would like to use the task scheduler. however when i use the task scheduler i cannot get 1:1 output even though there is an option apparently to select this. Ha anyone else experienced this and is there a solution. I am using Solidworks 2007.
RE: 1:1 DXF output from task scheduler
Chris
SolidWorks 08, CATIA V5
ctopher's home (updated Aug 5, 2008)
ctopher's blog
SolidWorks Legion
