Minature Linear Slide Motion Problems
Long time "looker", first time "poster".
I am currently having trouble with the motion on a minature linear slide (less than 1" long) used to control the motion of cantilevered arm of small mass. The motion of the slide is affected when we torque the arm down to the threaded holes on the top of the bearing cage with M016 caps screws- the greater the torque, the greater the impact to the motion to the point it seizes the bearing cage on the rail. The application requires a minimum torque to prevent vibrational loosening. Thread locker is not an option. I've considered looking at alternate fastener material. Any other suggestions?
RE: Minature Linear Slide Motion Problems
Are you using an off-the-shelf linear slide? Which one?
A sketch or photo would help.
As Corblimey says a sketch or drawing would be helpful in understanding your problem.
desertfox
locating surfaces are tightly controlled for flatness. Bearing motion is great until torque is applied. We speculate we are distorting the bearing cage in some way - perhaps as the threads elongate?
http:
What is the rail fastened to?
Are you torquing the screws while holding the bracket or the linear slide block?
Are you matching/exceeding the bearing manufacturer's recommended tolerances?
Using the recommended number of fasteners on bearing and rail?
Have you called the bearing supplier?
Tried a different bearing?
It probably doesn't take much torque to sieze as you say because of the size.
Is there any way to redesign to center the load under the rail car? That may only be an improvement, but still may be out of the inertia range on the slide. The other options are to do the above and see if you can upsize, or add another rail to offset the loading. Depending on your space constraints you should hopefully be able to come up with something slick to remove the large offset loading.
Most of those rails are designed for a load to be directly above the car and not off to the side and underneath it.
James Spisich
Design Engineer, CSWP
What you are experiencing is pretty typical for this application if installed wrong. I recommend talking to your rail manf. for additional info.
If that's the case, I'm not sure it has to do with the moment on the cart. You'd have problems right from the start.
As dvd suggested, make sure your screws are the correct length.
Is this a stock rail and cart? If so, it would behoove you to call the manufacturer.
V
> Either the bolts are too long, in which case, you should see gouge marks from the bolt protruding onto the rail underneath. I would saw one of the arms to remove the load, and bolt to the slider and see how it feels.
> Your attachment may not be perfectly flat with the slider mounting surface, and torqueing the bolts may distort the slider to the point that it's off its bearing groove. The lip feature shown in your model is also suspect. If the slider lip does not mate perfectly with the corresponding feature on the arm, then torqueing the bolt will bend the the slider or the mount or both.
TTFN
Along the lines of what CBL said, put a couple of washers between the mounting plate and the bearing cart, they don't have to be thin, but should be the same thickness, a reasonable fit on the bolt and not too big on the OD, this will ensure that the pull from the fastener is concentrated around the holes and the cart will not be distorted if the surfaces are not flat enough. If you can now torque it up and it runs OK, then either the cart was being distorted by concave faces or ridges near the edges and pinching the rail, or the bolts were too long and thus binding on the top of the rail. If it runs but not as free as you expect, try supporting the offset weight with a finger and see if there's any difference.
Hope this helps.
Check flatness of frame mounted to slide. Just a scratch will make a difference. A flat grinding stone will remove most of the defects.
A more forgiving slide like Del-Tron could also help.
Shake proof washers like Nord-Lock http://www.nord-lock.com/default.asp?url=51.16.37 If they come small enough
