Material to Use Against Silica Scale
Deal All,
We have a nozzle which frequently clogged up due to silica scale. We use softened water that passes through this nozzle. Are there any material as a replacement of existing nozzle (stainless steel) to protect silica scale to attached on the nozzle?
kenngy
kenngy
RE: Material to Use Against Silica Scale
How about adding a liner with an acceptable material inside the nozzle, and replace it when silica scale is at unacceptable level in case the softening process correction is not an option?
I am just brainstorming, it may not be acceptable due to some reasons in the process or complexity and size of the vessel.
I guess you need to come with details of the process if these can not help.
Hope it helps.
Ibrahim Demir
