Which standard stipulates UT inspection 24hrs after welding?
I've been trying to find a standard reference (ASME,AWS) that requires a UT inspection 24 hrs after welding carried out on process piplelines. I just cannot remember which standard it was mentioned in? I would appreciate your help in this regard.
RE: Which standard stipulates UT inspection 24hrs after welding?
I have searched ASME AWS and API, I cannot find where it sates in any of these codes that UT has to be completed in 24hours after welding has been completed, could have been a clients specification that you read to come up with this statement, do you remember who the client was ?
AWS D1.5, not pipeline but maybe there's a related provision in D1.1, which I don't have access to right now:
6.26.5.2.  Acceptance of welds in ... Grades ... 100-100W steels shall be based on NDT performed not less than 48 horus after completion of the welds.
12.16.4 (fracture control plan) gives minimum cooling times for UT, MT, VT:
fillet welds on Gr. 50 or less, 24 hours
fillet welds on > Gr. 50, 48 hours
groove welds <= Gr. 50, weld depth <= 2", 24 hours
groove welds <= Gr. 50, weld depth >2", 48 hours
groove welds > Gr. 50, weld depth <= 2", 48 hours
groove welds > Gr. 50, weld depth >2", 72 hours
Hg
Eng-Tips policies:  FAQ731-376: Eng-Tips.com Forum Policies
I know it is not an American code, but EN1011-2 "Recommendations for welding of metallic materials - Part 2: arc welding of ferritic steels" states in section 18:
"Due to the risk of delayed cracking, a period of 16h is generally required before final inspection"
Don't worry about non-American standards, there is a world outside! Here's a British one: BS 4515-1 for welding of carbon steel pipelines demands that the qualification test weld be inspected 24 hours after completion unless otherwise stipulated
Steve Jones
http://www.linkedin.com/pub/8/83b/b04
