continuity testing
continuity testing
Hello everyone,
I'm trying to measure the circuit protection diode of a certain pin, the problem is I have a bypass capacitor connected. Unfortunately, there is no way to disconnect that cap. I can measure ~0.5V, but I need a high settling time prior measurement. Is there a way to speed up my testing? Thanks in advance.
RE: continuity testing
Glenn
htt
Glenn
TTFN
@IRstuff - this is an input pin. Maybe the one who designed the DIB did not foresee this would happen. He could have put a relay to connect/disconnect the cap, depending on the tests. By the way, this cap is recommended by the device datasheet.
Reverse may, or may not, be OK. Typical reverse breakdown is around 30V, so there's be about 30 mW of power, which is not a big deal. However, avalanche breakdown can induce hot electron effects that tend to trap electrons in the field oxide, thereby reducing the breakdown voltage in the region.
TTFN
