HDPE 30% Glass Filled
Hi All,
We are using HDPE(Without GF) now and it's showing unwanted value of 60~70 MPa of stress now.
So for better "Tensile Strength" & "Yield-Strength", i want to shift for HDPE with 30% Glass filled.
And here problems come into picture, as i don't know any reference for basic difference between cost and changed properties of New HDPE with 30% Glass Filled.
Please let me know any reference or suggestion to come up for solution.
Warm Regards..........
RE: HDPE 30% Glass Filled
Prices have been volatile recently.
Material suppliers in YOUR area should be able to supply current quotes for unfilled and identical except for 30%GF material.
Pat
See FAQ731-376: Eng-Tips.com Forum Policies for tips on use of eng-tips by professional engineers &
http://eng-tips.com/market.cfm
for site rules
Pat's right that PP is a better choice than PE.
If you only need a modest boost in yield strength then talc or mica will work and will be cheaper than glass fiber.
Chris DeArmitt
"Knowledge has no value except that which can be gained from its application toward some worthwhile end."
Think and Grow Rich - Napoleon Hill
