Problem with Files
Problem with Files
When I open an excel spreadsheet, it opens 8 other excel files at the same time. If I close the 8 files I don't want, there is only one loaded, but if I close it and re-open it, I get the 8 other files again. Any suggestions? or is something set that causes excel to 'remember' the previous eight files?
If you want to see the problem, I uploaded a file into Concrete Formwork engineering under my name Dik and the other files are attached.
Dik
Dik
RE: Problem with Files
View and window settings of a particular file are saved.
Try open the file, close all the extraneous windows, SAVE, close.
Check the list of links under the Edit menu, option Links...
Cheers,
Joerd
Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips.
I'll check when I get home... thanks
MintJulep:
eight files, not the same one 8x
Dik
