Part History User information
I would like to know is there any way to remove part history information such as User and Program data. Some time if we oass our UG file to others, we want to keep these data confidential.
Please refer to the attached file for more info. I also observed these informations were removed in the UGCAST training files. Thanks in advance.
Using NX 5.0.6
Using NX 5.0.6
Raj
NX 5.0.6
RE: Part History User information
File -> Export -> Part...
...and select the 'New' option specifying a new Part File name. Then using 'Class Selection' select ALL. Set the Feature Parameters to 'Retain All Parameters' and Expression Transfer Mode to 'Copy if Referenced' and then hit OK and a 'copy' of you file will be created with NO HISTORY other than the current session. Note that Part Attributes are not copied, so you will have manually 'Copy & Paste' those yourself (Object Attributes however will be copied OK).
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Cypress, CA
http://www.siemens.com/plm
But the thing is I have seen UGCAST training files contains history tree with empty user and program data field (as shown in my previous image file). I am curious to know is there any option to remove these details. Since program field shows complete directory path of the part file.
Raj
NX 5.0.6
John R. Baker, P.E.
Cypress, CA
Most of our clients who send us sensitive models use the parasolid export option.
Bill
Thanks for sharing the information. Still I am curious to know any option to remove those information without loosing the model feature tree.
Raj
NX 5.0.6
