HELP! I need to embed a revision table in a .slddrt!
Going thru some design changes, and now need to change the template that the drawings have. I usually right-click the sheet, and browse to the appropriate customized .slddrt file to do this. However, I actually need a revision table in the .slddrt so that one is generated every time the template is replaced.
I understand that one can save sheet format template in .slddrt and revision table template in .sldrevtbt, but I have not been able to save one into the other. Once I try Save Sheet Format, the Revision Table disappears.
Help! Thanks, all!
Help! Thanks, all!
RE: HELP! I need to embed a revision table in a .slddrt!
Chris
SolidWorks 08, CATIA V5
ctopher's home (updated Aug 5, 2008)
ctopher's blog
SolidWorks Legion
I am trying to change the templates for existing drawings by doing a property change, instead of opening up a new drawing and selecting the drwdot. drwdot will not show up if you do a template change on existing drawings.
The difference isn't that huge, just a couple steps extra, though I do have to do this to 200+ drawings :(
Thanks for the tip!
Sounds like you need a macro to first switch the sheet format (.slddrt) and then add a Rev table.
