Technical Term for Bolt Backing Out?
Is there a more technical way of saying that a bolt is backing out?
I am writing a service bulletin and want to let the customer know that a bolt tends to back out over time.
RE: Technical Term for Bolt Backing Out?
Bolt is loose
Bolt is unscrewing
Premature bolt extraction
Bolt doesn't want stay put
Best I can do
TTFN
The fastener can get longer due to creep or yield.
The the length's of things can change due to differential thermal expansion.
Loose bolt without rotation.
TTFN
-Dustin
Professional Engineer
Certified SolidWorks Professional
Certified COSMOSWorks Designer Specialist
Certified SolidWorks Advanced Sheet Metal Specialist
relaxation
reversing
e.g.:
"Dat dere sumbitch gon' back hissef right outta dere".
Mike Halloran
Pembroke Pines, FL, USA
Mike Halloran
or you could use Mike's "vernacula" prose ...
We have found that lock wire doesn't really work as a retention device but more like an indicator (if lock wire is broken you bolt is loose.
Nordlocks do work very well but I don't have the counter bore.
I must admit I'm surprised you say you've had lock wire breaking from it backing out only under vibration, though, unless these are fairly small fasteners and thereby requiring a small diameter lock wire. Granted my experience mainly lies in gas turbines in regards to lock wire so you're talking a minimum of 1/8" wire.
In any event, as you said you found a permanent solution so its a moot point, I was just throwing a brain dropping out as curiosity often gets the best of me.
That says it all!
Bill
"Why not the best?"
Jimmy Carter
