Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...Thanks a lot Mate! I can't tell you how many times your site has saved my "rear". hehe..."
Geography
seanclarke (Electrical)
31 May 02 16:54
We have a DH+ network of about a dozen AB SLC5/04's throughout a domestic and wastewater treatment plant.  There are several PC's on the DH+ network running SCADA software.  I want to be able to design an IIR filter to process some of the data (analog inputs).  Is it better to try to program a 5/04 to do this, or should i use a PC?  thanks in advance!
FrancisL (Computer)
3 Jun 02 7:26
It depends on the complexity and time sensitivity of what you want to do. Most PLCs, and I think the SLC 5/04, have some standard analog input filtering functions but they may need some fairly simple programming to implement. If these do what you need then keep it in the PLC. You can also program some simple filtering yourself using math functions.
chriskei (Electrical)
3 Jun 02 8:59
I would lean towards integrating the solution in with your existing PLC structure.  This keeps the hardware in one place and typically PLC solutions are more reliable.
Chris Keith
ATS
Close Box
Join Eng-Tips® Today!
Join Us             Close
