How to do combined broken view in drafting bench?
Some one ask me how to do a vertical and horizontal broken view in one single view.
CATIA v17.
I can only do it with some work around.
Do you guys have better solution?
CATIA v17.
Forever Young.....
RE: How to do combined broken view in drafting bench?
Forever Young.....
What I did, don't know if it's better, but it's associative atleast, is to copy the view three times so I have four and then cut them down one by one with "Clipping view profile" to finally position them where I want.
Azrael - your suggestion is good - but only if you have the standard settings set to hide the clipping lines on 3 out of 4 sides. (it should remain at the break line) If this is not specified in the standard, the lines come back every time you update the drawing/view.
I can't use this method with a lot of customers because of this constraint. (and I am not allowed to change their standard)
Catia Design|Catia Design News|Catia V5 blog
The thing is that I still need to dimension the overall size. It is hard to do it cross views.
What I can think about is to create bodies for the corners in part, then make the drawing view. and use fake dimension to dimension the overall size.
Forever Young.....
