Push Assembly Level Cut Features to the Part Level
Hello All,
I was wondering if there is a way to push/move cut features that have been created at the assembly level to the part level in SW2008?  Example, I have an assembly of mating parts and I created a bunch of cut features related to features on the mating part.  Now I want those new cut features to show up at the part level so I can generate a machining drawing for the part.
SW2008 SP5.0
Thanks all,
BB
RE: Push Assembly Level Cut Features to the Part Level
The easiest way to do that is to upgrade to SW2009.
Else, you will have to create the cuts while editing the parts inside the assy.
Thank You CBL
