Horizontal Truss conn
Working on a large industrial project with horizontal trusses at the roof instead of using steel deck diaphragm. Designed with wide flange chords and diagonals and planned to use top and bottom gusset connections to the flanges. The roof slopes 1/4"/foot so would it be better to skew intersecting beams and column cap plates the 1/4"/foot or just try to use shims?
RE: Horizontal Truss conn
