Footprint area of haul truck 797B
Does any body know the footprint area of haul truck 797B (400t)? I tried to search on line, but nothing is found.
Thanks for your help!
RE: Footprint area of haul truck 797B
http://www.cat.com/cda/layout?f=227126
I check the link that you gave. Under 'dimensions', I can't find the footprint areas of front tires or rear tires.
http://ww
I also came across this research paper:
http
You should show standard tires on the 797B to be 59/80R63. See if you can locate a copy of the CAT Performance Handbook. In addition to the specific section on the machine, there is a separate tire section that may be of help. On second look, no luck there. You are to consult Michelin or Bridgestone directly for 797 options.
