Stres formules roof support construction
LS.
1. Are Roark's formules as designformules for the roof support/crown construction of a storage tank acc to API 650 the only formules accepted or is the ENV 1993-1-1 also an acceptable methode?.
2. Does the EN 14015 accept the Roarks formules as designformules for the roof support/crown construction of a storage tank acc to EN 14015
Kind regrds
Kind regrds
RE: Stres formules roof support construction
Does Roark have anything specifically for tank roofs, or is this just the flat-plate formulas you're referring to?
I'm not familair with the formula's but I saw only Roark's formulas mentioned in a calculation. The were not completely write out just the outcome.
