Setting all active default in assemblies
Moved over to SE ST and can't find setting to make all parts active as default.  When I try to assemble parts I find parts are not active and I have to activate.
Finding manual difficult to follow.
Getting lazy.
Any help welcome.
RE: Setting all active default in assemblies
you mean that after open an assembly all parts are inactive? If
so, the option can be found there where it has always been:
Application button  -> Open --> Type *.asm then select your
file but before pressing open set the options and press
'Save As Default'
HTH
dy
Thanks. Worked perfectly. Amazing how difficult to see things when they are right in front of you.
