HEAT PUMP vs FURNACE/AC
In a cold country like Canada, do heat pumps work in the winter?
Do heat pumps have any advantage over conventional furnace and air-conditioning systems (for houses).
A company in Maine manufactures so-called "low-temperature" heat pumps - does anybody have any experience with this line of products?
RE: HEAT PUMP vs FURNACE/AC
Canada's a big place. Any particular region you're concerned with? NWT, Yukon, Maritimes, Prairies, Mountains? Coast? I'll assume you're talking about air-source heat pumps.
The issue with an air-source heat pump is that the colder it is outside, the less capacity is available for heating. Which means, you need a larger and larger heat pump (with electric heating coil).
Likely, this will result in oversizing (with much cycling) in the summer.
A secondary issue is the efficiency of the heat pump (COP). For the sake of argument we'll say that an air-source heat pump is 3x as efficient as a gas-furnace (I would argue this is only true in mild temperatures as the efficiency also drops at very low temperatures). The cost of electricity as a heating source ranges from 1.5X to 4X the cost of natural gas, which frequently will eliminate any cost benefits.
A final issue is that I have never seen an air-source heat pump capable of operating down to my lowest design temperature, I imagine other cold countries would have this issue.
Often the 'low temperature' feature is an electric heating coil that kicks in when the outdoor temps get too low for the heat pump.
