Material of the CV Boots nitryle or chloroplene
I wonder why in car industries material for CV Boots was changed from nitryle to chloroprene rubber. Would you like to give me the answer?
Thanks in advance
Gregor
Thanks in advance
Gregor
RE: Material of the CV Boots nitryle or chloroplene
You are absolutely right with the low temp performance - I've just checked it in the table. But I am curious if it is the only (together with the cost) parameter which allow using CR instead of nitryle rubber.
