spiral staircase (going mad!!)
hello people,
i have to draw this spiral staircase in AutoCAD but its pretty messy even on the architect manual: looks like every method i apply is wrong! (since i have to check a certain distance on a certain point and its not matching)
so im NOT asking about blocks and stuff, just if u know some page/site/link or w/e comes to your mind that may help, some scheme...i dont know...showing how to geometrically construct the staircase.
i underline that the spiral staircase with all the steps aiming to the center of the middle pillar its not my case.
thanx in advance
thanx in advance
RE: spiral staircase (going mad!!)
Obviously, you'll have to calculate the pitch; the amount of center post that each tread will need and even make it a little longer than the calculated value since when you UNION the excess will be incorporated in to the center post.
The tricky part will be to draw the circular handrail; so draw it a little longer for one tread in the X-Y plane as a solid and rotate it about its lower end in the X-Z or Y-Z plane a calculated angular value.
Once the ellipse is drawn in the x-y plane only take a portion lining perpendicular to a typical tread whose center will line up to the minor diameter of the above ellipse; then rotate that portion of the ellipse about the center of the ellipse a value of the lead angle. make sure the portion of the ellipse you select to rotate is sufficient to union with other arrayed tread as mentioned in the previous post.
A little complicated and if you are not familiar with the math mentioned above get help from an engineer. Once you complete this project, the experience will be gratifying.
Then when you copy/array this tread, do the same with the point. Then, when you are done you will have all the treads and a series of points 42" above each stair. Put a spline through the points to get a path for the handrail.
-- MechEng2005
same concept?
In Autocad use the Helix command and draw 1 revolution, diameter x Height.
Then use list and it will give you all the information you need.
If you want a 3d model of the handrail, rotate the UCS and put it on the end point and draw a circle, explode the Helix just once, then extrude the circle and pick the Helix as the path. This will only work with a circle any other shape will twist as it goes around the Helix.
As for the fabricator all he needs to know is the diameter, height and length.
Its a bit of hit and miss getting the first one right, the tube has to be rolled and twisted at the same time, not a easy job,
Best of luck.
I hope this helps.
Dave
