Changing CONFIG in workbench
I get the following error in ANSYS Workbench when doing a flexible dynamics simulation:
 *** ERROR ***                           CP =    2183.203   TIME= 22:50:21
 Number of results on results file exceeds maximum of 1000.
  Maximum may be increased with /CONFIG command.
I'm not using APDL (batch script), so is there a way to change that config in workbench?
Kindest regards, and thank you very much.
RE: Changing CONFIG in workbench
Solved:
Insert command:
/CONFIG,NRES,1e6
Actually it didnt work out, maybe because I get:
!   Commands inserted into this file will be executed just prior to the Ansys SOLVE command.
!   These commands may supercede command settings set by Workbench.
And it must be set in the beginning of the file.
Any ideas?
Final solution:
FINISH
/CONFIG,NRES,1000000
/PREP7
/NRES,,999999
