API - how to find named views and traverse?
I don't have any code to post for this question yet because I cannot even find the methods to use for this:  How do I get the names of the named views in a part?  I wish to traverse all named views and save them to an array, then search for a particular name or names.
Matt Lorono
CAD Engineer/ECN Analyst
Silicon Valley, CA
Lorono's SolidWorks Resources
Co-moderator of Solidworks Yahoo! Group
and Mechnical.Engineering Yahoo! Group
RE: API - how to find named views and traverse?
ModelDoc2::GetModelViewNames, perhaps?
Sample code:
CODE
Dim swApp As SldWorks.SldWorks
Dim mDoc As SldWorks.ModelDoc2
Dim vViews As Variant
Sub main()
Set swApp = Application.SldWorks
Set mDoc = swApp.ActiveDoc
vViews = mDoc.GetModelViewNames
Stop 'check your Locals window
Set mDoc = Nothing
Set swApp = Nothing
End Sub
batHonesty may be the best policy, but insanity is a better defense.bat
http://www.EsoxRepublic.com-SolidWorks API VB programming help
Roland,
Thanks for the help...this is what I came up with:
Dim Part As SldWorks.ModelDoc2
Dim ViewList As Variant
Dim i As Long
Sub main()
Set swApp = CreateObject("SldWorks.Application")
Set Part = swApp.ActiveDoc
  ViewList = Part.GetModelViewNames
  For i = 0 To UBound(ViewList)
     If ViewList(i) = "InstantView" Then Call ShowView
  Next
  Part.NameView "InstantView"
  MsgBox "InstantView did not exist.  New InstantView saved from current view.", vbInformation
  Set Part = Nothing
  End
End Sub
Sub ShowView()
'Part.ShowNamedView2 "InstantView", -1
' There is an error with ShowNamedView2 that does not
' allow this function to work as expect in drawings in SW2007
  Part.ShowNamedView "InstantView"
  Set Part = Nothing
  End
End Sub
This, and the companion macro are available here:
http://sw.fcsuper.com/index.php?name=UpDownload&req=viewdownloaddetails&lid=128
Matt Lorono
Silicon Valley, CA
