Customize middle mouse to rotate/orbit instead of pan
Is there a way to change the middle mouse button to rotate instead of pan the part?
The only thing close to a solution I've found is to map the middle button to F4 but then I still have to press the middle and left buttons for it to work. I want to be able to just press the middle mouse button to rotate.
RE: Customize middle mouse to rotate/orbit instead of pan
Boo Inventor for not giving us full control over our own input devices.
Seems silly to rotate (which can be a complete 3d motion)using a 2d input tool like a scroll wheel
I wonder if Inventor pans because 2D Autocad pans and they didn't want to change the function of the middle button.
Regarding the space navigator...The $99 one wouldn't work for me because I would constantly be going back and forth between it and my keyboard to use shortcuts. I can't justify the price for the higher end ones with more buttons and my company won't spend that much either.
I know this isn't really the place for it - but is there anything else in 2010 that helps model rotation and view control like this?
