Missing rigid plates when run, result seems correct
My model simulates two rigid plates compressing a helical coil spring. However, I don't see the two plates in the result, just a line. However, the result seems to be correct. What is wrong?
RE: Missing rigid plates when run, result seems correct
The plates are analytical surfaces and are defined as only a line. Use the sweep/extrude feature in view options to make them appear as plates.
corus
Please attach your project, to be checked out.
Mohammad Shahbazi
www.OmranAfzar.com
I didn't mention that the model didn't converge, it stops at Time = .16,
I tried to reduce the step time but it didn't help.
I could not open the file please compress cae and jnl file in a zip file and attach it again.
Good Luck,
Mohammad Shahbazi
www.OmranAfzar.com
Do as Corus suggested. No need to post your file.
