nastran to workbench
We want to translate our femap/nastran model into Ansys Workbench. We first export the solution from Femap in .dat file. After that, I created an Fe Model in Ansys Workbench with this file. But when I want to create the initial geometry from mesh, an unknown error appeared and suggest that we should change the tolerance angle. I changed tolerance angle to 5 and after to 90° and the error come back again...
What's wrong ?
Is is neccessary to create an initial geometry to enter in the simulation page ?
May I use Ansys classic instead of workbench ?
What's wrong ?
RE: nastran to workbench
The initial geometry from FE-modeler is necessary if you want to go to Simulation in Workbench. In FE-modeler you can select ANSYS as target and exporting the CDB file.
regards
