Problems using "circular array" on a "draft"
I am just wondering if anyone else has had any problems in NX4 with using a circular array of a group, where one of the features in the group is a draft. It seems that the circular array does not array the angle of the draft correctly. So as the draft gets copied around the circle it changes angles and does not copy consistently. Does anyone else have exterience with this or know how to avoid it?
Rick Gaston
Rick Gaston
RE: Problems using "circular array" on a "draft"
How are you applying the draft - from edge option or face option? What are you using as your vector reference? If you pick an edge that is going to be in the array then the taper direction for each instance may change.
Best Regards
Hudson
www.jamb.com.au
Nil Desperandum illegitimi non carborundum
