UGII files importing-sw says"unknown error opening **.prt
I'm trying to import some ugII files, and since the extension is the same as solidworks files it acts as if it's trying to open a solidworks native file rather than import a ug file. Is there anything special I need to do to convert these files into sw 2008? I'm pretty sure that I've converted UG's in the past with no problem.
Any feed back is appreciated
RE: UGII files importing-sw says"unknown error opening **.prt
Jeff Mirisola, CSWP, Certified DriveWorks AE
CAD Administrator, Ultimate Survival Technologies
My Blog
I remember that the "pkg" extension means it was probably created on a Mac, i don't think windows can unzip it without a third party program. Try Googling the extension!
Trevor Clarke. (R & D) Scientific Instruments.Somerset. UK
SW2009x64 SP2.1 Pentium P4 3.6Ghz, 4Gb Ram ATI FireGL V7100 Driver: 8.323.0.0
SW2009x32 SP1.1 Pentium P4 3.6Ghz, 2Gb Ram NVIDIA Quadro FX 500 Driver: 6.14.11.7751
And what happens? Does it return an error message?
Can you post a sample UGII part to experiment with?
The error is this:
Unknown error opening c:\directory\defroster.prt.
Windows does hijack that extension to SolidWorks when installed on a computer which already has UG installed.
"Good to know you got shoes to wear when you find the floor." - Robert Hunter
So what vintage are the UGII files?
Cheers,
Anna Wood
SW2008 SP5.0, Windows Vista SP1
IBM ThinkPad T61p, T7800, FX570M, 4 gigs of RAM
http://www.solidmuse.com
http://www.phxswug.com
This file will not open in NX, leaving me to believe it is not a UG file, but one from a different system (CadKey, ProE, ?).
For for UGV10 versions and above solids became the standard way to make a part. Prior to that (15+ years ago) 3D wireframe and surfaced wireframe was the way to go.
I assume that SW had a hard time dealing with all the curves and surfaces in the model.
NX should have no problem opening pre V10 files (or any version, as that is one of their bragging points).
