Humidity sensors?
Humidity sensors?
Humidity sensors?
Has anybody used humidity sensors to keep mixed concrete Water/Cement ratios as constant as possible.
If so what do you recommend.
We use crushed limestone aggregate.
Best wishes
RE: Humidity sensors?
I have a product (actually 2 units) that is manufactured by LASCAR that records temperature.  The data is downloaded  via USB.
It can be set for a recording interval and the information saved can have an elapsed time of 'years'. or the rate of recording can be increased and the duration is reduced.  I'm not sure what I typically use, but it can record temperatures every 30 sec. for a duration of a month.  This is software configurable.
They also manufacture a device that records both temperature and relative humidity.  I haven't used this and in hind site I should have purchased these; I didn't know about them until I received the temperature data loggers.
The units are robust, compact and within 1/2 a degree (checked this).  The software is easy to learn and the data provided is great, you can set operating limits and the devices will note when limits are exceeded.  Very happy with the LASCAR and you might want to start with them for the temperature, relative humidity loggers.
Dik
Thanks Dik
