Blending Parts in Assembly Mode
I have a question regarding blending two parts when they are Assebmled in the Assembly mode. I made a wing as a part file and made the fuselage as a part file and then i assembled them together. Is there some how i could blend them or should i just make them as 1 part?
I tried to add them as a part through the insert-->assmbly features--> Add.. but that didn't work out so well. A lot of things were highligted in the option popup window. Any advice would help. Thanks!!
RE: Blending Parts in Assembly Mode
Make the blend in a separate model. Search the internet and your online documents for "contextual design" or "external references".
Catia Design|Catia Design News|Catia V5 blog
Now I don't know if this is the right way because you are not explaining why you would like to do this. Why do you want to do this? there could be other, better, ways
Thanks for the tip but I don't have R19 or R18. Is there another way in blending two assembly parts together? (that or some how creating a fillet)
Did you not take my advice from my last post? (it will get you exactly what you need)
