Contact definition Abaqus - Help needed
 I am trying to model contacts in layered (plastic over linear viscous) solids. I am running into a problem.
Once the deformation begins, the viscous body flows more easily and comes into contact with a different face of the plastic body than the one it was initially in contact with. My question is
1. How do I model (in CAE) deformable contact between two solid faces that are initially unrelated, but will eventually come into contact with one another. What contact controls/adjustments are recommended for this type of analysis. I would like to model the whole process in one time step.
Thanks in advance
SS
RE: Contact definition Abaqus - Help needed
The faces don't have to be in contact initially in order for you to create a contact pair for them. So just create a contact pair for them in CAE and it will work once they touch during the simulation.
I am agree with vumat721
Mohammad Shahbazi
www.OmranAfzar.com
Thanks Vumat and Mohammed.
