Rotate command dismissing?
Up until ST, when I use the rotate (or move) command in DRAFT, I could rotate items one at a time without having to reselect the command.
Now, it seems to want to dismiss to rotate (or move) tool after each use. If the copy option is selected it remains active.
Any ideas how to keep the tool active? I find myself having to often rotate items in the type of parts I am creating (need a random look to the parts) and manually rotating them is the only way to achieve this.
If it dismisses to tool after each use it quickly becomes a nuisance to keep re-activating the tool.
Any suggestions?
-T.
Any suggestions?
-T.
