Matching an Aluminum alloy to ZAMAC 5 properties
Hi!
I'm working on a design of an aluminum component that will allow me to phase out my current ZAMAC 5 product.
I'd like to switch to Aluminum for several reasons, including the weight of the finished item, as well as the ability to anodize. However, I can not jeopardize the physical properties of my product by reducing hardness, shear strength, etc., and would like the finished product to have (almost) the same properties as its ZAMAC 5 predecessor.
The components will be die cast.
Any help in identifying the correct alloy to use is greatly appreciated.
Josh
Josh
RE: Matching an Aluminum alloy to ZAMAC 5 properties
I have already received confirmation from my factory that they are able to cast the parts in aluminum, but they were unsure of what alloy to use for the initial tests.
I will have them begin with A380.0F for testing, and we'll go from there.
Thanks again!
Josh
Keep in mind that anodizing performance of high pressure die cast alloys in general is not good. The high Si alloys 380/383/390 have poor appearance, while the Mg-alloyed grade 518.0 has the ability to produce anodized parts with excellent cosmetic/aesthetic appeal. 518.0 is similar to 380 in terms of strength, better for elongation. The problem is that it is significantly more difficult to cast into thin sections/intricate shapes without cracking or forming other types of defects. Make sure you are working with the anodizer together with the casting company to optimize the final product performance.
We are making parts with very intricate shapes and thin sections (<1mm) for the consumer goods / general merchandise industry. Therefore, I do not believe that 518.0 will be suitable (solely based on the previous reply).
If I use A380, can I barrel plate the parts as I currently do with ZAMAK?
What is meant by "poor appearance" of high Si alloys?
Josh
http://w
