WPS & PQ for HDPE welding
Good afternoon,
I am currently working on a power plant project which is being constructed to ASME B31.1.
Before HDPE welding, Client request WPS, Operator Qualification Test, and Procedure Qualification Record for HDPE welding.
1. What code should be applied to Procedure qualification for HDPE welding?
2. What kind of test method should be applied to Operator Qualification Test?
Please, anyone who has experience in HDPE welding would be appreciated.
RE: WPS & PQ for HDPE welding
Here's what's done on pipeline work,
http://www.phmsa.dot.gov/staticfiles/PHMSA/DownloadableFiles/Files/6%20with%20addendum%20-%20Guidance%20Manual%20-%20Small%20Natural%20Gas%20Systems-2002.pdf
Most of the manufacturers have their recommended procedures you can down from their websites.
"Pumping accounts for 20% of the world's energy used by electric motors and 25-50% of the total electrical energy usage in certain industrial facilities."-DOE statistic (Note: Make that 99% for pipeline companies) http://virtualpipeline.spaces.live.com/
AGA Plastic Pipe Manual For Gas Service
Process Industry Practice PNSC0036
Installation Of HDPE Piping
Plastics Pipe Institute TR-33/2006
Steve Jones
http://www.linkedin.com/pub/8/83b/b04
