UG NX total time/hour tracker for part files
I was wondering if UG has some sort of way to track the amount of total hours that were applied to a part or assembly file??? I'm trying to compare design time (hours in a file) from a UG file to the same design time on files from another software. We have a UG model returning to us that was done by an outside contracted firm. I'd like to verify the firms claim to hours needed to the actual info found within the UG files (if possible).
Thanks in advance,
Gary
Thanks in advance,
Gary
RE: UG NX total time/hour tracker for part files
if you go the modeling appl. you can use the
Information --> Part --> Part History...
option.
You will see the creation date and hour and how many time they saved the part/assembly, on different dates and times. You cant roughly estimate the duration in days for working on that part.
But if they left the part open for one day and saved once in the morning and once in the evening you cant be sure that they in fact worked all day at the part.
Hope this helps a little.
Kind regards
Michaël
attached a screen shot where to find it, and an example output.
Greetz
Michael
Thanks again-
Gary
"Good to know you got shoes to wear when you find the floor." - Robert Hunter
