Pool water storage and discharge tank
I have a pool that once every two weeks will drain at 300 gpm to be sent to the ww facility. The issue is the facility cannot take this load all at once. I need to find a tank that can store the water volume (1500 gallons) and send it to ww facility at a reduced rate of flow. I am having a hard time finding the right underground tank to perform this task. Does anyone know of any tank vendors with such an item?
RE: Pool water storage and discharge tank
The OP has not stated what kind of water the pool contains-public swimming facility or other, and so we cannot assume the water is clean.
The tank issue has been answered by others. However, I am very interested about why you are draining a swimming pool every two weeks. Among other things, it's a waste of water and whatever chemistry you are using therein.
I would like to hear further from you, as we may have some viable options to eliminate the draining process. Contact me at www.orendatech.com.
Orenda
Thanks everyone!
http://
http://w
h
